- Joined
- Oct 11, 2022
- Messages
- 369
I’m in the process of replacing my harmonic balancer and was thinking about replacing the three groove crank pulley with a two groove (I have AC and power steering that run off the first two belts and the pulley has a lot of surface rust in the grooves).
I saw this 5.75” OD pulley on wild horses: https://www.wildhorses4x4.com/product/Billet_Crank_Pulley_6668yr/bronco_pulleys. But mine seems to be 6.25” at the outer edges. Does this matter? Or could it be the mating surfaces are the same diameter and mine just has a bigger “lip”?
Here is mine:
Here is mine:
