Custom Crate Engines by TD Motion Performance?
BRBroncos
Looking to do a Coyote swap on a 70 Bronco and trying to find a good source for a Coyote and all the accessories necessary to swap it into a Bronco. Came across this website that seems to have exactly what I need but I wanted to check out how legit this website actually is before spending a bunch of money there. There's multiple names that the website uses as its title so I'm on the fence if it is legit or not. If it is legit it looks like it'd be a great place to get everything I would need for a swap all at once rather than having to get everything individually. Let me know if anyone has used this website and had good luck or if its just a scam site, or if anyone has any other suggestions on where I should source a motor and transmission from
https://www.mustangengines.com/?s=early+bronco&post_type=product&product_cat=gen-2-engines
73azbronco
Ouch, I think for $25,000 you can find a local machinist to build you two.
BRBroncos
BRBroncos
If I was in the market for a 'new' Coyote engine, why wouldn't I go for the latest gen 4 version with 480HP?
From the research I did the Gen 2 Coyotes are an easier swap than the Gen 4s due to less complicated technology. Would love some information to correct me on that though. I'm also not worried about the power aspect.
BRBroncos
BRBroncos
Strange first post. Almost like an underhand advertisement.
I have no affiliations with this website or company I was just trying to figure out if its legit or not. I am just starting out building Broncos and looking for advice.
BRBroncos
BRBroncos
A local Machinist that has a Gen 2 Coyote, 6r80, all the bracketry for the accessory drives I need and all the wiring harnesses? I am just looking for a place I could buy a whole Coyote swap package rather than piecemealing everything together through different sources.
EPB72
Pleasant Hill, CA
I don't know ANYTHING about this business, but I ran across it a while back. It seems to have some good resources for Coyote swaps. I think you can buy a chassis with a Coyote engine on it from them if you want. Not sure if they will just sell the engine and necessary components to put on your own frame.
https://patriotclassic4x4.com/colle...ucts/1966-1977-early-bronco-chassis-assembled
Yes Rich Smith , is a member here and has many post here,,..
any crate Coyote will be costly, especialy if it has a new trans .wiring and PCM attatched ..
about 6 months ago had to replace a trans on a 2021 yukon denali wholesale from GM was 8500$,add mark up and installation .. prices are just up there ......
PCB 4x4
Their prices are really high 😳
