D20 shifting issue
Cdra8925
Hey guys!
Planning on my first drive today and a full frame off and I realized I cant get the d20 J shift into 2h despite reviewing the shift pattern.
While the trans was in park, the Bronco was rolling and I thought it was a trans issue at first but realize it’s the Dana 20. When I shift all the way up it locks into gear and it’s in 4wd. When I go to where I think neutral should be it’s still in gear. When I bring it all the way back to 4H it will roll around when the trans is in park. The same is for 2H. The front yoke locks in 2H but the real spins freely when the trans is in park.
I had everything rebuilt and a local shop thought the d20 arms were installed backwards and it was a detent issue. Any thoughts??
gnpenning
Bronco Slave
Do you have a body lift?
Have you checked to make sure the linkage isn't hitting the tunnel?
Have you tried disconnecting the linkage and shifting the tcase?
I don't recall the details but I think you can put one of the gears in backwards and not get both high and low?? Hopefully someone else will chime in on this part since it's a recent rebuild.
C
Cdra8925
Yes I have a 1” body lift and after 5 hrs that was the culprit. FYI to anybody running a body lift!
ba123
CA
Good call @gnpenning !
Strange that you are hitting with a body lift but maybe the shifter choice? Which trans? Aod or something else long that moved the D20 back?
Sadly, you might need to take at least the D20 back out and swap shifter, assuming you can't while it's in there.
I highly recommend the JB Fab cables but depends on how you're set up and if it will work for you, you will most def have to take the D20 out.
Viperwolf1
electron whisperer
The input gear can be installed backwards and that will cause a neutral-like condition when the tcase is in rear drive, high range. It will not cause neutral for the front drive if the tcase is in 4 high (hubs locked). Low range will work normally.
To fix it, the tcase needs to be separated from the adapter housing. The gear is inside the tcase, but it is attached to the input shaft which can be pulled out.
