D44 ball joint tension nut?
Jaybr
Anyone know what thread size the ball joint tension nut is?
Have 1 out, still working on the second one, and would like to clean up threads before replacing.
My tap set goes to 1” and that’s not big enough.
Jaybr
Jaybr
Got the second one out, definitely need to chase the threads. It actually looks like the hole is oblong but I think it’s just at the top edge.
Jaybr
Jaybr
Found it 1.125-12 or 1 1/8” -12
Now to find a tap
Jaybr
Jaybr
Just following up for anyone who may run into this problem in the future. Purchased the tap on Amazon, a bit expensive but worked perfect. 10 minutes work and the tension nuts thread in by hand.
Tip: Run the tap up through the bottom first pass as the threads are probably still good on that side. Mine where only messy at the top, and very messy after having to remove the nut by turning it with a chisel.
https://www.amazon.com/gp/product/B00FXJYYSM/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Where are you by the way? Might be able to get some of that investment back by "loaning" the tool out for a few bucks, or selling it outright to another member in need.
Of course, if you're like me you just like keeping tools that you buy because you can. But something like this, with any luck, is something you're not likely to ever need again.
Jaybr
Jaybr
I’m in Chesterfield VA and happy to loan it out to any locals that need it. I tried to borrow one from my buddies that run a 4x4 shop but they didn’t have one. Can’t get rid of it yet, have another bronco waiting on the sidelines.
I did use the proper tool. One side came out with impact, some in and out massaging, and a lot of PB Blaster.
The second side came about 2/3 out then one of the tabs on the nut broke off. From that point I had to use a chisel and a big hammer to turn it a little at a time until it finally just fell apart.
Was going to try out my new welder and weld a piece of flat bar to the top of the nut to help but quickly realized I need to run a new 240v outlet with the correct receptacle
