dana 30 knuckle removal question
Ironlung1948
Hello folks. I'd like to start by professing my ignorance on the topic but I have a dana 30 that im taking apart. I cant seem to figure out how to remove the knuckle . I was able to identify the 4 bolts on the top and bottom of the knuckle are termed 'king pins' but i cant seem to figure out what they are for or how to remove them. I initially thought the metal plate was rusted to the knuckle so I started banging on it with a chisel until I released it was shimmed in there but I still did not get it to lift up. I presume that removing them is the only way to access the ball joints? Yelp
Bronconut
Sounds as if you are almost there. The four bolts hold the 'pins' in place. If you were able to get the pin to start coming out then you just keep going until it is fully removed. Most likely it will require a little heat on the knuckle to free it up. These pins ride in bearings in the axle housing which allows the steering knuckle to turn. D30s do not have ball joints, these pins are your 'ball joints'
Hope this helps.
66BlueGoose
Also, if you can spin it quarter turn it will allow you go get under two sides of it to help work it out. Try not to damage the shims, you will need those going back in. Be sure to get a new shim skit as you will most likely need spare shims to properly set preload when going back together.
I
Ironlung1948
Hope this helps.
It does help thank you. Makes much more sense knowing I dont have traditional ball joints.
