Dana 30 needle bearing greasing .
428kidd
So I need to grease the needle bearings in my 70 Bronco. I saw this trick piece a guy built to to the job with out completely disassembling the front. Any one else have a better way or a tool that is made for the job? Thanks Lance
https://postimg.cc/23yjWN76] [/url]
Look up or search “spindle luber“ and see if anyone still makes the tool.
I have one for my bronco and one for my pick up that are made out of machined aluminum with the proper threads and a grease fitting.
Very simple and straightforward.
428kidd
Dirt , I googled it but no luck and none on eBay. Would you want to loan me the one for the bronco if I pay freight back and forth to you?
What? And miss out on seeing how you cobble one together like in the first picture? Ha ha!
Where are you located?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
428kidd
So I finally got around to getting this made. I used a small piece of 1 1/4 pcv pipe. A 1 1/4 couple and a 1 1/4 plug. I threaded the plug for the grease insert at the end. Drilled a hole as close to center as I could get it in the back . Used a fine thread coarse thread exhaust manifold bolt a few o rings and two nuts. It worked pretty well and got it done. I did have to make a small gasket the size of the spindle to seal it off once a lot of pressure is on it . Anyway here are a few pictures.
https://postimages.org/] [/url]
https://postimg.cc/nsZs9RF8] [/url]
