Anybody rebuild a Dana 30 lately? I have a '69 Sport with a Dana 30, keeping her stock and overhauling the front diff. Original shop manual ain't too clear about the pinion preload, which uses shims to preload instead of a crush collar. I THINK what the manual is saying is to torque that pinion nut down with about 220 ft lbs and then check the preload. If the preload is too high, add shims, if too low, remove shims. Is this right?
