I am trying to determine the correct method for setting the torque bearing preload on a Dana 30 front axle. The manual states “starting” torque bearing preload is the correct value (9-16 ft lbs). See a screen shot of the shop manual below.
Does “starting“ mean: torque reading the exact moment the steering knuckle first begins to move?
I do get higher readings during the torque wrench/knuckle travel especially as I turn the torque wrench and the knuckle gets closer to the knuckle turn stop bolt(full turn). I get around 11ft lbs once it starts to move but tends to increase to about 16-18ft lbs during the torque wrench travel.
Any thoughts?
Jeff
Any thoughts?
Jeff
