I realize there are gobs of threads about getting the upper balljoint torqued correctly, but for some reason I just can't seem to get it quite right. When I set the spacer to 40 ft/lb and tighten the big top nut to 100 ft/lb, the actually ball joint itself will twist when I move the knuckle back forth....assuming that is NOT the correct way to do it. If I tighten the spacer MORE than 40 ft/lb, the balljoint stops twisting but the pull force on the knuckle is now more than the spec of 26 pounds. Anyone else run into this?
