- Oct 11, 2007
- 401
I installed a new set of 4:56 gears in my Dana 44
Set my pinion depth and preload then checked backlash And tooth pattern. Got the pattern and backlash set to speck. Removed carrier, torqued pinion set up nut to 190ft. Rechecked pre load with all new bearings and races no seal or outer baffle my preload was at rotational 20-22in pounds.
That’s what new bearings call for from what I’ve been able to determine. So I removed set up nut installed outer baffle and pinion seal. Torqued new lock nut to 190 and pinion felt super hard to
Turn. So out of curiosity I rechecked preload with seal still installed and I’m at rotational 50
Inch pounds now!
So my question is could the seal actually be causing all this extra pressure? I know it will cause some but this is a lot!
I’m using a seal I got from bronco graveyard and it seems to be built different than the old seal
I removed. Like it has an extra thick sealing surface that goes up in to and presses to the back of the yoke. Pic is of the part of the seal I’m referring to
Inch pounds now!
