I started the teardown of my Dana 44 today and things have gone well so far. I’ve got everything taken apart but for the knuckles. I did have one spendle bolt that broke off in the drum knuckle but I’m upgrading to Disc so not worried about that.
I have yet to order any parts for the rebuild as I wasn’t for sure what all I would need. As luck would have it, looks like everything is JUNK and needs to be replaced.
I found what looks to be a complete kit but I’m not suer as this is my first Dana rebuild. Hoping you guys can help me out as to what else may be needed.
Kit description:
All needed parts to rebuild the internals of a Dana 44 including all bearings and seals, u-joints and wheel bearings and seals. Excluding ball joints. Dana 44 Front Rebuild Kit Includes:
PINION BEARING GROUP:
-Timken Head Taper Bearing Set
-Timken Tail Taper Bearing Set
CARRIER BEARING GROUP:
-Timken Right Hand Taper Bearing Set
-Timken Left Hand Taper Bearing Set
SEALANT GROUP:
-Pinion Seal
-Gasket
PINION SMALL PARTS GROUP:
-Dana Spicer Pinion Depth Shim Set
-Dana Spicer Pinion Pre-Load Shim Set
-Dana Spicer Pinion Nut & Washer Set
CARRIER SMALL PARTS GROUP:
-Dana Spicer Carrier Shim Set
-Amenities Package
-Hub seals
-Timken Inner wheel bearings and races
-Timken Outer wheel bearings and races
-OEM u-joints
-Inner axle seals
-Dana Spicer OEM spindle bearing repair kits
Other than the 4.09 ring and pinion for the front (to match the 4.11’s I just put in the rear) what eles if anything do I need? Would like to get everything in one order and have it ready.
Tim
Kit description:
SEALANT GROUP:
-Pinion Seal
-Gasket
-Amenities Package
-Hub seals
-OEM u-joints
-Inner axle seals
Tim
