Hi,
I have an problem with the dash panel lights (gauge cluster, primarily) not working when the headlight switch is pulled on. It's an intermittent problem, so I suspect that it may be a ground issue.
I know trying to chase down an intermittent problem is difficult. And I know there are lots of things that could cause the problem. I'm just hoping that maybe there's a known weak link for the problem that I might start with first. (I know the process may be a lot more involved.)
Has anyone else tried to troubleshoot a similar problem? Any solutions that you found?
Thanks for any advice you can provide.
Jeff
Jeff
