Daves 71 NH Build
dave67fd
dave67fd
Thanks Bri. If your too busy and/or it's more convienient for you i can stop over. Either way let me know.
I need to replace a piece of the frame. Should i use the same thickness or close to it? or can it be thicker? I obviously won't use thinner. Im pretty sure the frame is about ~5/32" (.145) or so.
dave67fd
dave67fd
Thanks Pete.
Don't hurry on my part;D. Although It gave me a small jump, still many leaps and bounds away.
Sounds like you guy's had quite a nice trip to SC.
dave67fd
dave67fd
Put a couple hours on the frame this weekend.
Cut-off the piece of angle a PO welded on the rear frame rails (trailer hitch). They had folded down the inner frame lip so i will have to pound back in shape or just weld a new lip in.
Also got the bad shock mount off and as i had expected a hole behind it.
Got my frame washers (i only need one) and will weld on shortly. Will have to look into the shock mount if i can buy just one.
71massbronco
You will be surprised, I think, on how fast your progress will go once you get that frame stitched up. If you aren't waiting on goodies from UPS, it goes together fast. Looking good!
dave67fd
dave67fd
That's kind of my plan. Hope to maybe get one replacement rear shock mount, double rear shock mounts and front shock hoops. That way i can pull the oem front shock mounts and get ready to POR it.
How's the new welder treatin' you?
Pretty good. I've been practicing. Seem to do pretty well with it i think. Is more getting the machine set were i want it for the metal thickness. Comes with a setting chart for an ok starting point but trying to dial in a bit better.
Here's a couple of my practice. Far from perfect but almost good enough to start on the frame.
dave67fd
dave67fd
Thanks Brian. I actually had replaced the rear shock mounts on mine many years ago and was thinking of using one as they are pretty solid but i figured trying to get it off with the body and tank on would be a pain and not planning to pull the body untill prob. the fall. If it's in really good shape and it comes off without issue great. If not no worries. I think JBG has them for $20.
broncoitis
Lookin good Dave and those welds look pretty good as well for someone that just started. Looks like you cleaned up the weld with a wire wheel prior to the pic but looks good to me. Keep it up. ;D
dave67fd
dave67fd
Thanks Man. I just hit it with a fine SS wire brush. I need as much help as i can get.;D
Stutsmo
Dave,
your practice welds are better than my finish welds! ;D
dave67fd
dave67fd
Dave,
Well, I'll see were I'm at when i actually hit the frame. That will be the test. I'll be more concerned with adhesion than beauty at that point.
dave67fd
dave67fd
Was able to get the rear frame horns lower inside lip's back into shape. A little heat and got them to form back pretty good. Also added a bit of filler welds on where it cracked slightly and ground them out smooth. Touched it up with the Etch primmer. Not perfect but close enough.
tasker
all knowing of nothing
NH
looking great Dave! now you'll be done in no time...
dave67fd
dave67fd
Yeah, Maybe if i had one of these. I gotta get your attitude to rub off on me abit more.;D
tasker
NH
keep the faith, maybe body party on sunday?
migs
Might actually be quicker to build that time machine;D;D
...I'll have to check, but I might have a spare flux capacitor in my parts bin.:p
dave67fd
dave67fd
Wow!! You have one? That's my ticket out. Have the giant Gyroscope up in the loft. Ohh!! wait a minute i still need HG Well's notes on how to turn the damn thing on.
