Daves 71 NH Build
dave67fd
dave67fd
ALOT there to soak! keep after it Dave.....proud of ya!
Thanks Brother. Hope I can keep it semi-consistant.
I love pulling out the torch and giving them some heat! Works every time for me!
Yeah, I didn't spend much time with it. Pretty much jumped on the ratchet with a breaker pipe and didn't break loose. If she don't break with the heat, OFF WITH HER HEAD!!
dave67fd
dave67fd
pics and more pics to keep ya honest!
Ok here ya go. Got some hours on her today.
Got the rear frame spot cut-out and the plate fabbed to fill it. Put a slight bend in it to match the curviture of the frame. Took some time but fits nicely.
Got the tow hooks off the bumper with some heat and cleaned up the scale on the innerside. Revealed the PO sig welded into the bumper. Year was 1988. Same year I purchased.
dave67fd
dave67fd
Got that frame piece welded, cleaned up and primed today.
tasker
all knowing of nothing
NH
very nice DAVE! we all need a push.....keep after it!
MR-CYN
NH
Nice job Dave. You should be ready to bolt some axles on that bad boy soon.
dave67fd
dave67fd
Thanks for the encouragement guys. Wish i could use cardboard, i have plenty of that available lol.
The motivation is there it's more just finding the time to get to it.
I'm almost ready to start welding on the bumpstop brackets and the shock mounts in front of the leafs. Have to pick-up some weld thru primmer first.
Axles will be a while.
dave67fd
dave67fd
It's a Miracle!!
I actually found a couple hours to get back on this thing.
The frame had the front bottom frame rails cut back about 3/4" (half way between the bolt holes) probably for some custom bumper or some other reason.
I cut off two 1 1/2" pieces from the old frame to rebuild the front back to stock. I may decide to box these in later at some point.
That should do it for frame "repairs". Now I can start welding on the bump stops and shock mounts.
71massbronco
Damn, talk about factory fresh! Can't even tell they were missing. Looking good bro!
migs
looking good Dave! ...look at all that floor space, jealous!;D
tasker
NH
AMAZING! keep after Dave, need the inspiration
dave67fd
dave67fd
Thanks guys. Two or three hours here and there i guess ok. I hope to get a whole weekend in on her soon I hope.
Shock mounts! :p
Yeah, doing the dual shock mounts in the rear and replacing a rotted one.
I bought one from JBG that really doesn't fit well and seems cheeper made. Bought a set from Duff's that are perfect with better welds/construction so i may just not use the JBG one and buy a single from Duff's.
