Daves 71 NH Build
MR-CYN
NH
Thanks guys. Two or three hours here and there i guess ok. I hope to get a whole weekend in on her soon I hope.
Yeah, doing the dual shock mounts in the rear and replacing a rotted one.
I bought one from JBG that really doesn't fit well and seems cheeper made. Bought a set from Duff's that are perfect with better welds/construction so i may just not use the JBG one and buy a single from Duff's.
I'm pretty sure the first ones you got are the same ones I have on mine. ;D
dave67fd
dave67fd
Thanks Mikey,
About a month overdue but just got the son to help me flip the frame over early in the week and got a few pieces cleaned and weld primmered ready to weld on so stay tuned shortly.
dave67fd
dave67fd
Found a little time today to get back on the frame, Got my bump stop brackets and PS reinforcement plate welded and primmered. Next should be the dual shock mounts.
Crawdad
Keep up the good work! Do you plan to close off some of the holes in the frame? I know some are necessary but wondered if there are some to weld shut. Dirt dobbers loved those holes in my old 76!
dave67fd
dave67fd
Thanks. No, all factory holes will stay as they are. You really want to keep as much drain and breather holes as possible. Had my share of the daubers as well but if and when i finish this thing it won't be subjected to the elements or sit outside as a lawn ornament ever again.;D
dave67fd
dave67fd
Well almost two months without much progress but found some time to get the dual shock mounts welded on and the one and only driver side body mount.
dave67fd
dave67fd
Yeah maybe but you guys are still way ahead in the scheme of things and your younger;D
jmhend
love the story and you have a great start to giving the old bronco a face lift
dave67fd
dave67fd
Got to cleaning the inside of the frame. Purchased a steel flue brush and cut it down to fit. Used a snake fed thru the frame. Was tight pulling thru but worked the nuts. Forgot about the PS bosses on the driver side so i had to grab with channel locks and pry it through the remainder. Did the passenger side 4 times and the driver twice.
Didn't think i would get that much more crap out of it than i had previously cleaned out on several past occasion when flipping the frame. Unreal.
fatboy
Glad to be here.
New Hampshire
Maybe I can borrow that while you have the engine crane. ;D
Saw the PM, I am sure we can make it work. I want to pull the mountaineer motor before the snow flies but we are close enough. Lets get it to you soon!
dave67fd
dave67fd
No prob, Pete. I can pull my crap and get it back to you and help you with yours or vise-versa. Whatever suits you best or is more convenient.
The brush was a one time thing so your welcome to it. I doubt i'll have any future plans to clean out another frame.;D
dave67fd
dave67fd
Finally got to pulling the engine/tranny/TC as one. Many thanks to fatboy for usage of the hoist.
Built an engine dolly for the assembly out of a heavily reinforced pallet and added 5 hvy duty swivel casters to it. Took a little pushing/pulling and adjusting the hoist to get on the pallet properly but not too bad.
Will start pulling the axles tomorrow. Ill be here if anyone has a desire to swing by.
fatboy
Glad to be here.
New Hampshire
Looks good Dave! If I remember correctly the last time we were all over there, the rear axle was all but ready to come out. I can probably give you a bit of time tomorrow.
dave67fd
dave67fd
Your memory serves you well. Yes, Just need to lift the frame and roll the rear out. Will remove the tires and wheels. The front needs the springs, shocks, track bar and A arms removed.
No worries Pete, thanks, still easy enough stuff to do on my own. Only swing buy if your not busy or want/need to get out of the house. probably be out there late morn, early noon.
