Daves 71 NH Build
dave67fd
dave67fd
doubt it! let me know when you need another hand some night or weekend
Yah me too.
I know i can count on you R'. Pretty much small stuff for a while now. Hoping to get a nice bonus check soon for all the 60 hr weeks ive been doing and dump most of it into the axles/suspension.
You know you can swing by anytime just give me a jingle. We can find something to tear apart.
Here's my quick list.
1) Weld track bar bracket to frame.
2) Pull off remaining shock and weld in new one (I was going to leave this but just looks out of place with the three new ones). Probably a spot behind it anyway that needs fixin.
3) Paint frame internaly.
4) Mount/weld front shock hoops.
5) Paint frame externally.
6) Pull axles and third member out of 9".
7) Start D44 teardown.
dave67fd
dave67fd
Nice to see some of BONES crew picking up the pace on their builds.
Hope to be back on mine a bit soon as well.
Not much to report but ordered some pieces to build the Inventory.
WH's 3.5" rear leaf kit, 1" body lift, 9" brake drum kit, and SS brake line kit.
fatboy
Glad to be here.
New Hampshire
Those springs and that brake line kit look very familiar, I think I will go check out my parts stockpile tonight... :eek:
dave67fd
dave67fd
After spending a few attempts at the 9" brake drum removal finnally got them off. The passenger came off with minimal work but drivers shoes were frozen to the drum. As well, the passenger axle slid right out but the driver not so easy.
fatboy
Glad to be here.
New Hampshire
Stockpile?.....YOU HAVE MORE :eek:
UM...NO! ;D
I had one I had to smash off it was frozen so bad. Keep the momentum going, one of us needs to and it's not me! :cool:
migs
nice Dave!
I got lucky on two of my broncos...someone had already been in there before. but even still, on one of them I had to put the drum on backwards to use as a slide hammer to get the bearing to slide out.
dave67fd
dave67fd
progress! proud of you Dave!
Thanks for the kind word Brother.:-*
UM...NO! ;D
Haha, kinda the reason the bottom half of that pic of the drum is cut-off;D
I think you have done rather well under your circumstances. It will happen in short time.
nice Dave!
Thanks B, Well before the rig sat for 20+ friggin years, the entire assy was brand new. (axles and complete brake assy. anyway) Notice the thickness on the drums and the pads. Ultimately the driver side sucked with everything. It was the side that faced more of the elements I think or just coincidence.
dave67fd
dave67fd
Dug out some more of the rig in '90.
1st one is right after a bearing chewed up the axle. Notice the cinder blocks. Right after that, I swapped in the 74' large bearing rear, currie axles, all new brakes and Duffs axle truss.
My daughter was 5 in the pic. She will be 30 this year:eek:
dave67fd
dave67fd
Hitting some small stuff...Drilled and retapped both radius arms and one cap.
dave67fd
dave67fd
Finding some time to finally get things wrapped up on the frame.
Internal frame coating is complete, Duff hoops mounted/welded. If nothing else my welds are getting pretty good.
Final primer and top coat to go then I can start throwing parts on this thing.
Slednut10
Guru? That's funny!
Almost 3 months since your last post, Dave. I was beginning to think you threw in the towel! Glad to see some ambition!
dave67fd
dave67fd
Thanks guys
Noooo. That won't happen. Although almost three months, I have been slowly picking away at it within that time. Ambitions there just too much other stuff in the way but thats life. More to come soon.
