De rattling a 69 Bronco
Grey owl
Trying to achieve a nice driver but OMG the rattle noises are everywhere. So far I put in all new weather strip, new window felts, new rubber on all glass changed rear lift gate to gas struts, but the rattles continue. Any tips on eliminating rattles would be appreciated. That rear lift gate seems to be the main culprit.
1969
Reno, NV
Keep doing what you’re doing. Listen and address a rattle. Is there anything specific you’re wondering about?
.94 OR
Willamette Valley, OR
You might try this, plenty of vendors handle them.
lars
Been here awhile
NorCal flatlands
I’ve spent 30 years trying to de-rattle mine. Sometimes it seems like I was successful. Until the next rattle shows up. Good luck!
Every control rod, in every door and the tailgate, needs to be dampened. Whether that’s with insulation around them, through them or tucked in with, whatever.
Like they said, you have to track them down one or more at a time. Then keep doing it.
And when you pull the doors apart to silence the rattles, add new clips, adjust tension, add insulator rings around the lock button and do other things, spray some rubberized sound deadening undercoating inside the door cavities.
Tie things up under the dash. Make sure no extra wire bundles, plastic connectors, flasher relays, or anything else is unclipped or hanging loose.
Adjust all latches.
Adjust, readjust, re-readjust, and then readjust the readjustments, to the tailgate and liftgate latches. And when it doesn’t help, rinse and repeat.
Twice more!
Long successful, but a rarely tried cure for the liftgate rattle syndrome, is to create a couple of small L brackets to hold rubber bumpers, that screw to the opening of the top. This puts pressure on the liftgate itself when it’s closed.
First time I saw this was on a beautiful 76 that I was looking to buy with a friend in 78 or so. I immediately noticed during the initial test drive that it was probably the quietest, smoothest nicest driving Bronco I’d ever spent time in.
Owned by an employee of the Ford plant in Milpitas, he had done some interesting things. Including adding the bumpers/tensioners to the lift gate, and even adding a third windshield wiper!
Do you have the full wiper cover on? Make sure nothing‘s behind their loose. Including the wiper man. Make sure the door gaps are good, including between the windshield frame because all that stuff flexes and moves more than you think.
Steve83
1. Find a rattle, and fix it.
2. Repeat as needed. (y)
Soft irregular surfaces like cloth upholstery and carpet absorb noise; smooth hard surfaces like leather, vinyl, bedliner, cardboard (headliner), and painted metal reflect noise. This one was so quiet you could have a speakerphone conversation with the cruise set at 90mph, and the other person didn't even know it was coming from a vehicle - much less a 40+year-old 4WD.
(click this text to supersize)
73azbronco
internal to tailgate, and doors, need to slide some rubber tubing over the rods, not tight just loose. Cable tailgate arms remove 90% of the noise back there.
1/8th inch of bedliner, various dynomat layers, fiber insulated carpet. Makes it as quite as a modern jeep. Thats really not saying much though.
papy
what Steve83 said
and sound proofing makes a huge difference. My bronco has very little going on for noise and rattles.
buttle tape through out- a few layers over the wheel wells and tunnel
butyl tape and foam padding on ceiling, firewall and inner rear quarters
jute padding and toms HD carpet kit
very quiet and keeps cool in the summer and hot in the winter months
Speedrdr
Legend in my own mind
Paris, MS
My solution is much easier, and far less time/work involved.
1) Get set of headers.
2) install glass pack header mufflers.
You won’t be able to have a conversation if it’s running, but you will only hear a rattle if a connecting rod turns loose.
Brush Hog
NorCal
New body bushings helped mine out. It is still more stress free to just roll windows down and turn music up so I don’t hear every old squeak and rattle (and the occasional new one)!
ntsqd
heratic car camper
Upper SoKA
Look at the tail gate hinges too. There's a couple of different ways to reduce or eliminate the tail gate itself rattling on the hinges. The cleverest that I've seen is an aluminum button with some large o-rings in a groove that the tail gate rides on.
Those with a urethane button cause me to wonder if you're replacing a rattle with a squeak.
Colo77Bronco
Colorado Springs
Adjust all latches.
Twice more!
What DirtDonk said lol. Insulating the control rods with rubber tubing is the one that people forget.
Lawndart
Mine gets driven a lot. The main rattles on mine come/came from the tailgate and the doors.
Tailgate - not the OEM fold out supports, but the internal rods. Some vacuum hose can help. I have not completely solved this one.
Door - not the internal stuff, the windows and the inner door handles. I place a small bit of foam between the inner door handles to give some positive pressure on them and this works well. The windows are another beast. I need to replace all the felt tracks, but I have been using cuts of cardboard for years and it works great; just needs to be changed about once a year.
nvrstuk
PNW
I de-rattled mine in the '80's as we got tired of the rattlin' on 12hr one-way drives up north for fishing every month or two... plus just all the DD 200 mile trips...
This was decades before you could buy any part you wanted for a Bronco so all home-grown fixes..
I used UHMW on the tailgate top to act as a wedge to keep the top from rattling side to side.
Used bicycle inner tube over the tailgate "arms"
Used vacuum tubing over the control rods inside it
Bought "nail-on weatherstripping for doors for sealing the bottom of the tailgate to the back edge of the floor. Set it in there TIGHT and it helped keep the lower tailgate from bouncing around on the large pivot pts (round balls) on each side.
Huge diffeence for the rear
Then the doors- do what everyone suggest above plus what you've done for wind noise already and you'll be pretty close...
Good luck as I think most of us that drive our Broncos more than once a month to the store have chased these rattles.... :)
toddz69
Never-ending quest to quiet things down and I always feel like I'm losing the battle when I get on a good washboard road. On my recent Baja trip I noticed one thing that made a bunch of noise was my brake pedal. So it got a new set of bushings yesterday.
The door strap screw holes on the driver's side were in bad shape for years too and that little bracket rattled so some nutserts in the panel fixed that one too. I know there's more noises coming from down there that need to be chased but I can cross 2 off the list for now.
Todd Z.
