msweb
- Joined
- Aug 29, 2003
- Messages
- 2,377
Stuck in the mud in two wheel drive, I casually had my neighbor's son jump out into the mud and lock in the hubs. The whole time, I had to listen to "My GMC wouldn't have gotten stuck". I laughed and shrugged it off knowing that once I put it into 4-wheel low and snapped his head into the tailgate, the last laugh would be mine. ;D
I grabbed the T-Case shifter (a J-shift pattern) and went for 4-low. It wasn't there. I tried again and again. Nothing.?:? The shifter handle seemed to be disconnected from the linkage and slightly rotated as I moved it from position to position. My 4-wheel drive is DEAD and the rear axle is BURIED in the mud. "My GMC..." going non-stop next to me and now the engine temp is climbing as fast as mine. Great.
Long story short, we had to winch out and unlock the hubs. It was the longest 10 minute ride home of my life.
I'm fairly new to EB's and NOT a manual T-case mechanic. Hoping to find a simple piece of linkage broken or disconnected, I popped off the inspection plate on the drivers side of the trans tunnel but didn't find anything
Is there something that holds the shifter into what I think are the shift rails (I've been doing soe on-line reading and I think these are what the bottom of the J-Shifter goes into)? I read something about a "lock-out pin" but don't know what that is or where to look for it. I'm not physically able to get under the truck and inspect everything and was hoping to diagnose the problem from above. Any ideas???
What would break or fall off to allow the shifter handle to just move around in circles and not shift the T-case? I read of some "flags" being cut when installing a twin-stick (which I'm planning on doing). Could it be a broken "flag" or "lock-out pin"? ?:?
Any help or pictures of these things would be GREATLY appreciated!
Thanks in advance,
Bronco dummy learning the hard way...:'(
Thanks in advance,
