Dead and Buried - Help!
msweb
Stuck in the mud in two wheel drive, I casually had my neighbor's son jump out into the mud and lock in the hubs. The whole time, I had to listen to "My GMC wouldn't have gotten stuck". I laughed and shrugged it off knowing that once I put it into 4-wheel low and snapped his head into the tailgate, the last laugh would be mine. ;D
I grabbed the T-Case shifter (a J-shift pattern) and went for 4-low. It wasn't there. I tried again and again. Nothing.?:? The shifter handle seemed to be disconnected from the linkage and slightly rotated as I moved it from position to position. My 4-wheel drive is DEAD and the rear axle is BURIED in the mud. "My GMC..." going non-stop next to me and now the engine temp is climbing as fast as mine. Great.:mad: Long story short, we had to winch out and unlock the hubs. It was the longest 10 minute ride home of my life.
I'm fairly new to EB's and NOT a manual T-case mechanic. Hoping to find a simple piece of linkage broken or disconnected, I popped off the inspection plate on the drivers side of the trans tunnel but didn't find anything
Is there something that holds the shifter into what I think are the shift rails (I've been doing soe on-line reading and I think these are what the bottom of the J-Shifter goes into)? I read something about a "lock-out pin" but don't know what that is or where to look for it. I'm not physically able to get under the truck and inspect everything and was hoping to diagnose the problem from above. Any ideas???
What would break or fall off to allow the shifter handle to just move around in circles and not shift the T-case? I read of some "flags" being cut when installing a twin-stick (which I'm planning on doing). Could it be a broken "flag" or "lock-out pin"? ?:?
Any help or pictures of these things would be GREATLY appreciated!
Thanks in advance,
Bronco dummy learning the hard way...:'(
YelloTx73
Katy/Galveston, TX
J-shifters are known to wear out and do exactly as you described. Check with Tom's or I think BC might have a new J-shifter kit to fix your worn out one. Also, do a search about J-shifters and that should also provide you with quite a bit of reading.
TexasBronco
Waterford, MI
you could always sink some cash and buy a twin stick. And since you will probably ask the advantages of that.
It should never not work.
You can chose
Front 2wd High
Front 2wd Low
4 High
4 Low
Rear 2wd High
Rear 2wd Low
You may ask why FWD only would be a good idea? The simple answer is....you will need it when you need it. Plus you can pop it into FWD high, set your e-brake and do a FWD burnout like all the ricers.
msweb
msweb
I like the twin stick upgrade and planned on doing it, just not this soon. this was a bad month for me, good month for the finance companies.
So a J-shift just wears out and quits working over night? Has anyone fixed one with the kit mentioned? Difficulty level? From what I've read in the other threads, a new twin stick on a J-shift is a fairly easy upgrade? Can it all be done from above?
msweb
msweb
NO!!! I just realized that I only have 3 days to fix my 4WD before the 4th of July!!!:eek:
What exactly wears out in a J-shifter and is ther a temp fix?? We're supposed to run the river on the 4th and I WILL need all four tires pulling!!
Eoth
Just my experience (I have a T Shifter) It often does not go into 4 wheel low all the time at any given position. Sometimes I have to back up or mess around a little before it engages. Being stuck in the mud without being able to move it around a little might have been the death of me. Have you tried it again after you got out of the mud? I try to anticipate when 4 wheel is needed and engage it BEFORE I get stuck.....
77TexasBronc
Baytown Texas
You mentioned you had an inspection plate. leave it off and shift the transfer case by hand when needed. may want to place a towel of something back over the opening for easy access and to keep from getting your butt wet. ;) ;D
Bucmaster
My j-shifter went bad much in the same way as yours. Pull the shifter out, 2 bolts, take it apart by unscrewing the round part. You will see that a roll pin has broken. Find a long bolt the same diameter and cut off the threaded part and the head till you have the right length. Drive it in. Reassemble. Mine has been like that for 14 years. Still a little loose but it works fine. At least till I put the twin stick in. I'd temp fix it for the weekend and then order the twin.
msweb
msweb
Thanks, but I don't think I can manage that while running the river. You can ride shotgun, do the shifting for me AND hold the match so we can drive, shift, and light fireworks all at the same time. ;D :cool:
msweb
msweb
I found the problem...
Bucmaster said:
My j-shifter went bad much in the same way as yours. Pull the shifter out, 2 bolts, take it apart by unscrewing the round part. You will see that a roll pin has broken....I'd temp fix it for the weekend and then order the twin.
Unfortunately, it wasn't the roll pin. Actually, I didn't find any trace of a roll pin. I did find the problem though and it's not one I can fix. The housing that the shifter seats in was broken. I was going to post a picture of it but I'm not allowed to do that ? ?:?
After reading past threads I decided to bite the bullet and do it right. I called Tom's and ordered a twin stick and boot. I didn't get the mass buy price, I missed out on that one but I will have the twin stick by Friday, installed by Saturday (hopefully) and will test it Sunday. Gotta love credit cards and 2nd day Fed Ex!!
Just one more reason to celebrate the freedom that so many have given their lives to protect!! Is this a great country, or what!!!! ;D ;D;D ;D
