- Oct 12, 2023
- 78
A question on my 74 EB with a disc brake conversion a PO did I am guessing 8-10 years ago. Truck is all stock except I see someone did a brake conversion to power disc front brakes and 11" rear drums. Brakes work ok but upon disassembly I see that a small portion of the front pad is not completely in contact with the rotor. It is actually partially off the edge of the rotor. That portion obviously has no wear on it. All components show little use since being installed. The brake caliper seems to me like standard Ford fare. I was just wondering if this kit was from let's say, TOMS, would it take standard 1975-77 Bronco pads or are special pads? Thanks in advance.
