Disk/Drum Braking issues
lonicus
Costa Mesa
I have a chevy front disk/stock rear system powered by a Vac booster. Prior owner installed the system and I have never had very good braking, but need to get this sorted once and for all! The truck will stop, and under normal conditions the brakes are fine. However if you need to stop quickly, it wont. It's like it reaches a braking limit, and then says,"OK that's enough, no more stopping power"
I thought it was my booster - which was cracked so I replaced it. However that did not fix the problem.
So I jacked up each wheel to see how the individual brakes are working. BOTH rear brakes are essentially useless. at full pedal pressure I can still move the wheel by hand (the brakes are applied, it resists me, but I should not be able to turn the tire by hand)
The fronts are better in that I can't turn by hand. However I don't trust at this point that they are getting full braking power either.
Something is clearly wrong in the rear. any ideas on what the problem is? (I did adjust the brakes, didn't help)
Skiddy
what kind of shape are the rear shoes, does your ebrake work?
B RON CO
Statesville, NC
Hi, hard to tell but you could check the rear wheel cylinders. I have seen wheel cylinders where one or both pistons are stuck, and they did not leak. Also remember the small primary shoe goes to the front, and the larger secondary shoe goes to the rear. Good luck
