Drum to disk steering linkage question
JohnJohn
Richmond
I have a D44 with drum brakes that I want to convert to disk. I have a set of 77 disk knuckles and spindles I want to use but I know it will require wider steering linkage. Is there a low cost option to just get a longer end link on the passenger side vs having to replace the whole linkage?
this is on my trail rig so I don't want to spend a fortune on it.
JohnJohn
JohnJohn
Richmond
I think I found the answer to my own question. I have 2 sets of 77 inverted Y steering linkage in my barn. It should work just fine for a 90% off road trail rig for now.
SteveL
Huge chevy guy
Hawthorne ca
I think the inverted y takes a different pitman with a smaller drag link hole. 66s,also have 5he small hole
JohnJohn, if you're going to use that Inverted-Y setup on a 3.5" lifted EB with 35" tires set up as an off-roader, I think you're compromising your strength and reliability.
If it's not street driven, at least you won't feel the wallowyness that most comment on, but you still have a long bar with force being applied near the middle by some pretty big tires. When in 4wd, that force is quite large and I know people who've twisted their Inverted-Y's long rods into cool taco shapes.
Maybe not a deal breaker, but still something to be aware of.
And as mentioned, you might need some sort of shim to fill the larger hole of your non-'77 pitman arm, or you can just get a different arm to better fit the linkage. I'd go for the shim if it's available.
JohnJohn
JohnJohn
Richmond
Thanks Paul. I am running 37's with H1 beadlocks with a 2.5" suspension lift and 2" body.
I can see bending a Y with these big tires.
