Distributor Cam Gear ID?
jeffncs
Raleigh, NC
I have a dilemma….. supposedly a stock 1994 5.0 engine which should have a roller cam. I didn’t build this engine nor have I taken it apart. I don’t have any reason to believe it’s been rebuilt based on normal bearing wear on the mains.
There wasn’t a dizzy installed in the engine at purchase (not concerned about that) which means I don’t have a starting point for the dizzy gear.
I can’t and don’t want to go backwards to take this engine apart. Should I assume it’s a roller cam or should I take a more conservative approach and use a bronze gear which will knowingly wear faster.
Am I overthinking this?
jeffncs
jeffncs
Raleigh, NC
Endoscope for the win…. Pulled valve cover, rocket and pushrod. I can see the retainer so it’s def a roller cam
Engine looks super clean!
Glad I ordered a steel gear this morning! (Leap of faith!)
Thanks!
nvrstuk
PNW
Melonized gear for the win. Works for all.
Never use a brass gear unless you are racing and tear it down every season... or more often. They wear fast. 2 guys I know got almost a year and then their oil filter was glittering with brass... remember these are non- DD's too...
