DIY Spray on Bedliner ?
bigpappa
Gardendale Al
Is there a DIY spray on bedliner on the market that compares to Line-x? If not what is the closest thing and how does it compare??:? ;D
trailpsycho
All of the roll-in liners (DIY) can be sprayed with a Schutz gun to the best of my knowledge. Some people are pro-Herculiner, some are pro-Durabak...check em out. www.herculiner.com and www.durabak.com (durabak comes in some cool colors and they will send you samples).
bigpappa
bigpappa
Gardendale Al
I am not a big fan of the roll on stuff. I am wanting something like the pros use that is able to get about 1/8 to 1/4 inch thick. I am just weighing options to see if I can get something like line-x for a cheaper price that I can do myself. If not I will just have Line-x sprayed in.
Any other opinions?
fox
none of the diy liners can compare to the spray on stuff. they are not as thick and if you try to roll them on thick they look horid. I work at precision 4x4 in clackamas and we spray stuff that looks like line-x but has 1000 pounds more tensile strength. I've had the famed rhino liner and the roll on stuff and would only use the stuff we spray and at the least line-x.
mag409
Central Pennsylvania
I called the SEM company today. They are the ones that make the kit sold on Eastwood. I talked to the tech guy and he made some interesting points. They sell two tintable kits one with a single catalyst and one with a 2-stage catalyst. The 2-stage catalyst is tougher. He stated that their product is not like the Rhino Lining or Line-X corporation, but it is not meant to be. Their product is intended to be used as a wearable liner. It does not have the wear characteristics of the high end spray on liners but it is a very durable product. The advantages to this product are that it is better then the normal DIY liner kits available today and that it is tintable. He stated that the surface of the single catalyst is spongy and not nearly as rough as the roll on liner kits. In general, I like to research products before buying them. If anyone is interested in their product I would recommend giving them a call and talk to them. In my case Im not looking for a liner product that will last forever, not that this wont, but rather my main purpose to a liner is to protect the valuable metal parts that our broncos love to eat.
Sorry for the long post but my opinion is that you only need a product that will meet your expectations. So if you expect the DIY products to last forever you may want to consider a high end product.
HotWheels
Twilight Zone
where u at? u another washingtonian?
fox
where u at?HotWheels quote:
nope from clackamas OR. Just south of portland, it borders portland. Thats where precision 4wheel drive is located as well. just off of Hwy 212 and 135th. We deal direct with B.C. and James duff. so if you want you can get their stuff through us.
I had to get set up as soon as i git my 68, it needs help.
MUDDY68
Cameron, SC
I used the sem stuff on my bronco. It is not as tuff as the line-x. I personally like it because it gives the bed a good texture. I sprayed it on and it was easy. I do not think it will last forever though. In fact I've already scuffed it, but it is a sinch to repair.
Fell out of my bronco while tack welding/fitting my full cage in place, took cage with me:-[ :-[ Hurt me more than the bedliner;)
broncoboy71
Virginia Beach, VA
How do you repair since it is a spray in liner. Do you need to respray with a gun or does it come in spray can or brush in
MUDDY68
Cameron, SC
When you buy the sem stuff you also have to buy the gun to spray it. Just clean the area, mix up some more stuff, and "spot spray" the scuffed places. The hardest part is getting the coat to be the same level as the rest of the bed.
