Do I need longer drive shafts? 2.5" lift
NYLES
Youll be OK! unless you got some wild lift with alot of travel, but if it just a 2.5 standard lift youll be fine.
daddyg
Bronco Parts Collector
Toney,AL
I didn't need to lengthen my drive shafts at 3.5. But I did at 5.5 so I think you will be fine at 2.5.
The front almost never needs changes. The radius arms arc nearly the same as the driveshaft so that is going to be fine.
Rear should be fine with only a 2½" lift. But Broncos don't always lift the same. So there is still a small chance that it may need replacment. But it would have to be marginal with the driveshaft at stock height to begin with.
blubuckaroo
Grease Monkey
Ridgefield WA
Better a little short than too long. %) (the driveline!) Too long and you'll wreck your U-joints when the springs bottom out.
broncnaz
I didnt need it with either 2.5in lift I installed but as others said check the rear shaft just in case you never know if someone happened to install a shorter shaft or the factory just shorted it. usually 3.5in lift is where you start running in to it being close.
Carl
Aurora, IL
I asked a similar question a few days ago: http://classicbroncos.com/forums/showthread.php?t=118236
My rear driveshaft looks like this now that I installed the new WH stock springs. My old springs were VERY worn out. So worn that the quarters would rub on my small 215/75R15 tires. The new springs lifted the rear up quite a bit.
Should there be play in the slip yoke? Because mine wobbles a little. I hear a humming sound only when I coast or decelerate. I thought it was due to a bad pinion bearing, but could a wobbly slip yoke cause this vibration?
broncnaz
Doubt its causing the humming. while not good to have wobbles it shouldnt be a big problem although it will probably cause Ujoints to wear quicker. I start considering either getting it respline or get a new D shaft.
Humming on decell I believe is to much backlash in the rear gears.
DonaldDouchebag
I lengthened my rear driveshaft when i went with a Wild Horses 2.5" lift. I wasn't cool with so little spline input. I think the entire shaft needed a rebuild anyway.
