dome light upgrade - yours?
SeaBiscuit68
Tacoma Wa
I'm fishing for ideas. I've been looking for something to mount on the roll cage, has bright LEDs, and is made well. Also it can't run on batteries. I want to wire it in as the battery game gets old. I haven't had much success for some reason so I thought I'd see what others have done.
Oh, as an aside, anyone ever try these under dash lights?
kylakekevin
I like those under dash lights! I have the led battery powered roll bar light from Toms in mine, battery's seem to last but I understand what your saying. I thought about fishing some wires through my roll bar and sticking a 12" led strip off ebay on the bar as they are very slim and wouldn't stick out that bad up there. I have had them on my golf cart for several years with no issues other than the sticky doesn't hold well so I used silicone. also used them on my sisters mobile vet unit for the night calls and she loves them.
hankjr
Oh, as an aside, anyone ever try these under dash lights?[/QUOTE]
the lights you link to are these with a metal tab and a nice upcharge
i put two of these under my dash and there will be two along the top of windshield frame. they do well and im please with the result.
the only complaints are that the wire gauge is super fine since the current is low and the supplied screws are junk. this is fine electrical load wise but a pain to tie into larger gauge wiring. not impossible to overcome. the screws that come with the ones i used under dash are made from chinesium. also no big deal. just throw in metal recycling and get decent ones locally
Hank
bronkenn
Bronco Guy
Southeast Ohio
I made some stainless steel brackets and mounted the LED's under the edge of the rear bed rail and they light up the rear of the Bronco really nice and are hidden as well.
JohnJohn
Richmond
I pulled a Pontiac Grand Am rear view mirror from the junk yard. It has two light switches and two lights under it. I tapped into the existing wiper dome light wiring I had. You can find them for $20 on eBay.
Viperwolf1
electron whisperer
How about some miniature LED mag mount rock lights.
Crush
Greenbottom, WV
Anyone have a wiring schematic on how to wire a three way switch in our broncos so that you can either turn off the dome light all together, have it actuate with a plunger in the doors, or turn it on. Also need to know which type of plungers to use. The ones that ground out the circuit or power it.
bmc69
In my '67, the infamous "Island Queen".. :cool:
SeaBiscuit68
SeaBiscuit68
Tacoma Wa
Great brainstorming, but I can't really go the Macgyver route. Also no wiper cover and it has to be on the roll cage for when the canvas top is being used.
Learning about the under dash lights is painful. I guess that's what having someone else do your fabricating cost$. I'm probably going to go with those anyway. I like that they mimic the originals, plus you get two for the price.
The closest I've been able to find to fit my needs is this one by SSV. From what I've been able to figure out, this version with the clamps means I won't have to route the wires inside the tube. I will have to measure the tube to get the right size. This would be outside diameter right?
jbawall
Edgewood, Washington
I used one of these:
https://www.amazon.com/KC-HiLiTES-C...ites+cyclone&qid=1565636870&s=gateway&sr=8-13
Wired it to the stock light, so it works with the light switch and used velcro tape to attach it to the bottom of the wiper cover, not sure I like that though.
They have a roll bar mount for it that is pretty slick, may work well for you.
https://www.amazon.com/KC-HiLiTES-1...ites+cyclone&qid=1565636923&s=gateway&sr=8-13
They have them in a bunch of colors too, made of metal, not plastic and bright as heck. I love mine.
John
SeaBiscuit68
SeaBiscuit68
Tacoma Wa
Thanks everyone for all the input. Every one of these ideas have merit and appeal to me in a different way. The choice had to fit the build, and of course every build is different. I almost went with the KC-Hilites because of the velcro strap, but in the end settled on the SSV.
To Crush,
I don't have a schematic, but it'd be fairly simple to do when you understand what you want to accomplish. The door plungers should ground the circuit. Safer that way. Look for ones that you can adjust the length. Use a piece of modeling clay to measure what size gap you're dealing with so you can know what to shop for. Wire your switch in such a way that it overides the plunger, in other words, provides a ground regardless of what the plunger is doing. I hope that helps.
jckkys
I've thought about this a lot lately, because the '77 is in the middle of a frame off restoration. I always hated the electric wiper box and that weak excuse for a dome light. To get rid of it, I went with a '73 FJ40 wiper motor. Now there's synchronized individual electric wiper motors to do the same thing. I don't mind using the headlight switch to turn on a dome light tho. Steve's photos remind me that lights are needed in front of and behind the role bar. The power can easily come from the wire used for the light in the OE wiper motor cover, keeping the headlight switch system. EBs are utility vehicles that can go topless, have a fold down windshield, or go full roadster. I can't see limiting any of the flexibility designed into EBs, so dome lights wired through the role bar is a good idea. I may even mount the interior rear view mirror on the front role bar. Dome lights could go on or in the middle bar and another on or in the family bar. I do love the idea of a functional fold down windshield, my M38 Willis flat fender was a lot of fun to drive with the windshield down. Red is good for keeping your night vision, but white is a better illuminator. There's a lot of choices.
SeaBiscuit68
SeaBiscuit68
Tacoma Wa
Simplicity and flexibility, Ford took those cues from Scouts and Willys and upped the game. Basically, EB owners have the foundation to go where they want and make it their own. So few pure stock ones remain because of that. One thing I always wondered about though. What was the original reason for the fold down windshield? If it was WWII and shooting while driving, why did it stick around? Hunting while driving? I did it a few times in my 68. In the mountains with door tops off and windshield down. It made me grin a lot, but I don't think that's what they had in mind or maybe so. I can say branches in the face and bugs in the teeth are no fun though.
