Door Gap Before and After
Jc.av8r
I made some adjustments to my striker posts last night in an effort to correct some pretty bad door gaps on my EB.
I have a separate post for why my drivers side is still not perfect, but the passenger side fix went pretty well. I'm curious to hear from others that have TBP quarter panels. There's just no way to get it perfect as it seems the factory door contours just don't match the rear panel. Still looks way, way better.
Before:
After:
Before:
After:
My bigger problem is the hood and I'm not sure where to even begin here.
RODRIG3911
Tucson
Do you have any shims under the hood hinges?.... I’d probably first loosen all your fender bolts and see if you could shift things up to line up better. Might have to add a shim under the passenger side hinge and remove one from the drivers side to get the length right first, then shift the fender around to make it fit better. It just takes time and playing with it.. I’m fighting with my divers side door lines too. It’s hard to get the panels/doors lined up right
RODRIG3911
Tucson
Looking at your doors it looks like both side need the door striker moved in just a tad. That might be about all you need to do to get them flush with the rear panels
J
Jc.av8r
Yep, I am unable to move the driver side post in any further until I can get the backing plate out and grind it down a few mm.
KBUCK1
Looks a lot better for sure. If you move the bottom hinge in just a fraction it would probably take care of it too.
Good luck
RODRIG3911
Tucson
I think i remember my plate being loose and able to move around when I replaced my strikers. I wonder if yours is stuck? Maybe shoot a little pb blaster at it from behind the pillar and see if you could knock it free and push it over.. If it's as far over as it goes and your rear quarter panels were replaced, they could have welded them just a tad too far in...
Just a couple thoughts for you man, hopefully you get more ideas from other people who know more. :)
