... So I was wanting to swap my 300cid over to a Saginaw pump but when I got to the wrecking yard I walked through about 200 Truck & found no CANNED HAMS.
But I did find one double Grooved org Ford Thompson pump. So I gave the guy $40.00 & he pulled it off.
... I got too install it this morning . So After I got it installed I went to town to get 2 new belts for it. 6 parts stores in town & The Napa store wanted 22 or23 buck a belt . Then noone else has 2 belts alike . So I finally got down to ORiely They had 2 that were about an inch longer . So I took them . I had lot of top adjustment .
... Put the belts on & .. DamnIt my top WP PULLEY the 2 OUTSIDE GROOVES didn't match . The grove toward the radiator Must have been for the AC. FRONT belt dropped down inside the groove making the 2nd belt tight & the 1st loose. So I get to start over. But I was able to run the Power steering in the front groove set up with one belt. I cranked it up & It didn't squeal like the other pump had been doing . & THE PUMP WENT RIGHT TO WORK . DIDN'T require lifting the front wheel off the ground to get good steering . I only had to twist it back & fourth about twice & I was ready for a drive in the pasture.
....... So Anyone know of a WP Pulley with 3 groves all the same size. Not one 6 7/8 & next one 7 inches . Not really sure of it actually size . I just pulled those measurement out .. But they are really close but not the same.
some pictures ...
...1st is the double in place .
...2nd is showing the WP pulley it's the one on the left
...3rd & 6th is old one I pulled off.
...4th shows the double groved pump Not sure what truck it really came off of .
... But mainly guys a double groove does exist . I do think it really came off a V8 Truck.
some pictures ...
