Drive Shaft Problems Created by Me Funny but Sad
fordguy
but it took me a couple of days to figure out why a stock driveshaft would not fit with a 2.5 inch lift. i have a 4r70w with an AA adapter. Duh. Guessing I will need a custom on the back due to it being shorter. Will see what happens on the now longer length needed on the front.
NGABronco
N. GA now South Carolina
If the ends work, shorten the rear shaft to fit the front and lenghten the front shaft to fit the rear. You only pay for 3 cuts/welds that way???;D;D;D
F
fordguy
Going to see what the front does since it longer length needed now. Will check the ends
SteveL
Huge chevy guy
Hawthorne ca
Depending how much the t-case moved it might bolt up but that doesn't mean it fits. Dont want the driveshaft coming apart over a dip. A coworker's brand new heep did that while he was showing it off in a lot across from the job
