I have a 1976 Bronco. I'm thinking about doing the dual electric wiper setup I recently saw in a Velocity Bronco.
It looks like there are 2 vendor options. One that syncs and one that doesn't. Curious if non-syncing also means that wiper parking will be off as well.
Toms version ($289) does not synch but includes wiper arms, wiring harness, etc. Note that the included new wiper arms are required.
Wild Horses version ($400) has a sync option for about $400 but does not include wipers, harness, etc but it looks like you can reuse the stock wiper blades. The sync function is built into the switch which looks like a marine-style rocker which requires cutting the dash. I'm not sure if the Velocity Bronco I saw uses the WH kit but the it looks like the same rocker.
I'm not really wild about either of these options, Tom's doesn't sync and WH requires cutting in the Rocker switch.
Thoughts? Thank you.
