Dumb Autometer gauge question.
SaddleUp
Vancouver, WA
Tachometer, Speedometer, Mechanical Oil Pressure, Mechanical Water Temperature, Voltmeter, Fuel Level, and Transmission Temperature. I wouldn't mind adding one for Fuel Pressure (using an isolator) and for the Air Pressure going to my ARB.
okorangebrnco
With my Projection, i am also running a air fuel, fuel pressure, and also an oil temp gauge.... i havent ever used the phantoms, since i op'ed for the lunars, but with Autometer you cannot go wrong
SC74
I have the Phantom oil pressure, water temp, and voltmeter - all mechanical.
broncow72
Village Idiot
Spring,TX.
Use a holesaw, but be careful. The holesaw will make a larger hole than it says (due to wobble slop).
Don't forget the clock to match all the other guages recommended there. ;D
Alan
supermottl
Indian Harbour Bch,
I have autometer in Speedo, tach, oil pressure, H20, fuel, volts. I switched from mech oil pressure to electrical and found there to be no difference in accuracy. I didn't like the idea of having that small capilary tube busting under my dash and squirting oil everwhere.
this is the tool i used... very neat, fairly quick, but also cut holes slightly larger than stated by the slider. No problems, that's what bezels are for:
72_EB
66to77
Saddleup,
I saw you were looking for a Fuel Pressure gauge with an isolator. I was looking to add one too when I do my injection, but the isolator models are only the 0-15 ones it seems. Wouldn't the 0-100 gauge be better for the injection? Whatcha think? Thanks.
P.S. Autometer Vacuum and Tranny Temp all right now here. ;)
j.r.nice
something to consider......even if you use the hole punch you will still need to modify the hole if you use the angle mounts (so the face of the gauge is toward you). Unless the hole is cut too big as mentioned above.
SaddleUp
Vancouver, WA
72_EB said:
Saddleup,
I haven't looked at them to pick one but you need one that will read at least to 50 or 60 lbs. The EFI should normally have about 40 psi if I recall right. If I get one it will be the Pro Comp series though which might make a difference. (Not all of the series carry all of the same gauges)
72_EB
66to77
Sport Comp. Didn't see it with the Pro either, but maybe I missed it. If you find it shoot me a part number. Thanks.
72_EB
66to77
I used a 2 5/8 hole saw an a dremel to clean the edges. My next project will have those angle cups too I think. I have to see what I need then for that hole.
Skipdevil
San Diego
I have a Autometer Cobalt fuel/air ratio gage hooked up to an oxygen sensor. I call it my "poor man's" EFI. It makes easy work of fine tuning the mixture on the carb. I run a single exhaust and installed the sensor in the exhaust Y pipe. For dual exhaust you will need two sensors and a switch to select between them. Be sure to mount the sensor(s) as close to the header collector as possible.
Skipdevil
ZookBronc
ZookBronc
South Orange County
Ok, so I got all the Autometer gauges...a 5 inch tach and speedo and some 2 5/8's other gauges. I bought some hole saws....a 5 inch and 2 5/8ths and i go and pencil up my dash overlay where i want everything and right before i put the hole saw to the metal I just by chance took a measurement of the back of the "5 inch" tach and it measeured 4 5/8 across!!!! Does that sound abnormal? The 2 5/8ths gauges are in fact that size but the 5 inchers are not.....does that seem weird?
Dazed and Confused
crawln68
Dazed and Confused
Just curious where you purchaced your gauges? I need to buy some soon. Thanks.
