Nice score on the harnesses. But unless there's some hidden "partial short-circuit" that is causing things to draw more current than expected, blowing 10 amp fuses seems suspect for sure!
I guess I really dunno for sure though. Not sure how much current a Duraspark is expected to use to do it's job, but while it seems 10 or so might be reasonable, blowing the fuses that quickly seems odd. I'm guessing most of that was the low-resistance coil? Maybe that's the extra that we're seeing here.
Seems like the ICM itself would only need a couple of amps at the most.
Sure be interesting to find out what's going on. Even though they didn't say it specifically, I wonder if Pertronix considers that coil to be incompatible with Duraspark, just like they say with the Flamethrower II coils. If I find out that's the case, I'll make sure we add that tidbit (kind of an important tidbit!) to our web pages. I used their own info to populate the text sections of our site with regard to the coils using info available just last year from them, so thought it was as up-to-date as possible.
Might also be worth a call to them if you have a chance. Before just sacrificing another module in the pursuit of Bronco-knowledge.
