It's hard to beat an all in one kit. Everything you need being delivered to the door is nice. Nothing to remove rust off of, nothing to paint, etc.
I like the challenge of sourcing all the parts myself. I went 79 bronco knuckles out. All the "replacement" parts I can get at my local parts store. Reused the stock drum/drum MC, H block and locking hubs. Picked up a booster and bracket off eBay. Had to get a few odds and ends but all in all it was an easy swap.
Tim
The Chevy version is easiest. You are not busting loose ball joints and tie rod ends. No alignment needed when done either. Just take off parts until you get to the spindles and start putting stuff back on.
I find the brake pad selection is better on the GM stuff.
Long term service parts, you can get what you need. And will for a long time. In either GM or Ford. But there are a lot more GM parts out there.
Now getting the parts...
The vintage of parts you need are getting into the classics. The square body chevy stuff is going up in value. The Ford stuff is getting rare simply becuase all the junk has been scrapped years ago and whats left is too good to scrap. So not much to be had. If you are good scrounging, have plenty of yards around to pick from and can get good prices the self shopping build your own kit can be a good way to go.
Anymore I would just buy a kit. All the parts are sourced. If something doesn't fit right you have a vender to go to for answers. You don't get stuck with buying the wrong set of spindles kind of thing.
Here's the list I used to convert my dana 44 drums to chevy disc 10 years ago.. I got this from the So.Cal Bronco's website in their tech folder.Keep in mind this is a few year's old and prices may have changed. Super easy to install..
Here's all the prices and part #'s These parts are all purchased from Auto Zone.
ALL PARTS ARE LIFETIME WARRANTY
#024196 0524 performance friction pads comp set $27.99
#095745 C503 RH disc brake caliper $12.99 +$10.00 core=$22.99
#095752 C502 LH disc brake caliper $12.99 +$10.00 core=$22.99
#048859 5492 brake rotor/hub comp. $30.99x2=$61.98
#788737 set 37 wheel bearing,Timken $13.99x2=$27.98
#788422 set 45 wheel bearing,Timken $13.99x2=$27.98
#704049 H5002 brake guide bolts $6.99x2=$13.98
#001799 313938 banjo bolts 7/16"x20x1 1/16 $1.99x2=$3.98
Total$209.86 without tax.Minus core charge of $20.00 new total=$189.86
I bought spindles and backing plates on craigslist.
Write up I used..
http://www.emotoman.com/disc/discbrake1.htm
So I pretty much just pull everything from backing plate out from a mid 70's chevy and bolt them on my axle? I am a junk yarder so wandering in a great thing to me! but they are getting harder to find!!!
