EB D44 question
snick
Is there anyway to tell ONLY by the EB factory Dana 44 housing if it originally came from 71.5-75 vs 76-77? I have one that's completely stripped of everything that I'm trying to figure out. I know that the upper frame track bar mount is a different size bolt but I thought I read somewhere that the axle side lower track bar mount was also slightly different (assuming it hasn't been modified from its factory location). Thanks in advance
If you're lucky, the original BOM (bill of materials) number is still visible and nobody has cleaned the axle up so much that they ground the numbers off. They were shallow even when newly stamped.
If they are, then it should be facing directly forward on the long side tube not far from the center section.
I never remember this detail, but I believe it's something like an eight digit number that starts with a 6. Could be the other way around though!
Look for that number and if you're lucky information is still available online. There are several sources of BOM information, including Dana Spicer themselves.
papy
just exposed the BOM on my 79.
7 digits as shown "123456-7"
Paul,
where online can we dissect the BOM?
  • BOM.pdf
papy
sorry i can never figure out the upside down pics...
I think someone has links to the sites, but there is a Bilavista page or three from Pirate, there is MrN's pages if they're still up and running after all these years, and then there's Dana/Spicer's site.
I'll see if I can pull one up.
S
snick
Thanks for all the replies. Unfortunately I'm not able to see any BOM codes on mine. Another question did all (clarification - not necessarily the early 76's that were built in late 75) 76/77s come with the welded anti-sway bar brackets on the D44s? I thought the sway bar was an option on 76/77s so wandering if no sway bar was 'optioned' at the Ford factory then were those welded mounts still included?
Apogee
Tangent, OR
My understanding was that all of the '76-'77 EB D44 housings had the sway bar bracket, but not having seen all of them, that's just what I've gleaned over the years, so take it with a grain of salt. My '77 has the bracket, but not the sway bar...no idea if that was how it was delivered though back when she was born.
