To D44, or not to D44, that is the question
bmc69
Pinion angle looks good from what I can see, and the upper ball joint is leaning back looks like at least 7 degrees. So did you cut the castings off and rotate back to get the castor angle you needed. Then find a c bushing that worked with it?
I always shoot for 6-7 degrees of caster. The arms you see on that...made by me. I didn't touch the outer castings...on that or any of the other "one-piece outer" 44s I've narrowed.
bax
Old Member
It's OK. It's Jon. He's used to having abuse heaped on him from Project Bronco and Blue Oval forum days. 😜
OK good. I didn't was to full on piss anyone off today
bmc69
Edit: Crap...it's hell getting old and old timers setting in...I just recalled that I had pulled the tubes from the center section in that one in the pic I posted.
bax
Old Member
That has to suck. How hard is that? Did you get James to help you?
bmc69
No worries. you and I have a long way to go to achieve "expert level" arrogance and condescension ratings.
bmc69
Much harder than I'd originally expected. Before I did it, I was not aware that the tube OD is finish-turned where it mates with the center and I also didn't know the axle seal seat is machined on the inner id. But that was all over 20 years ago. Fortunately I have a nice big lathe.... I belive you've seen it.
bax
Old Member
Yes I have seen it. I just picture the the big end of that tube spinning around taking out everything it hits.
Seventee
In the sticks of MT
Im going to be a little harsh here. Yes that pinion points too high. Put it in 4wd and go 50 MPH and that drive shaft will shake like crazy.
It doesn't. I rarely unlock my hubs and regularly do 10-20 mile highway runs up to 65 mph and never had a problem. Those are still the original u-joints from 9 years ago.
That's what I was going to ask about setting the pinion angle on the cast-wedge axles. Isn't it as "simple" (sarcasm added after the fact) as rotating the tubes in the center section?
And by "simple" I mean in theory, if not exactly in practice. Sounds like they're in there pretty good now. No more spun center sections under hard use.
So then these things are not like the old 30's that you could spin in the center section practically by hand, using the radius arms for leverage? Bummer.
Does the factory fully weld them, or just use plug welds in the holes. I've seen so many that were welded around the perimeter over the years that I've been wondering if it was done by the factory, or added later.
I always assumed that they were added later, but in more recent years I have not been so sure.
bmc69
Factory just the (rock hard) plug welds. I always add the heavy full-perimeter filet weld when I build them.
gnpenning
Bronco Slave
Since it came up in the discussion here are a couple pictures from a 74 F 100 D44 HP. They came with drum brakes from the factory and 3/8 tube with welded on wedges. You can see why the 76-77 is recommended. This will work though if you get the knuckles out for disc's. First picture shows the tube size.
You can see the tube is only plug welded from the factory.
Seventee
In the sticks of MT
Okay, so this discussion inspired me to measure pinion angles yesterday:
EB is +5 degrees in relation to the drive shaft, here's a better picture:
'79 F-150 is +3 degrees for reference:
So I have 2 extra degrees in the EB installation. If I replace my 4 degree bushings with 7 degree, pinion angle will be very close to spot on and I will have close to 7 degrees of caster without cutting and turning anything. What's not to like about that?
bmc69
Indeed...comes out right about perfect. Which sounds a lot like what I was saying..
