Edelbrock 1002 Pro Flo Air Filter
bingen
Cebu, Philippines
Can some one please take a picture with a tape measure placed beside the 'Metal Inner Frame' of their Edelbrock 1002 pro flo? I need to fabricate one, as I can't just go down the store here in the Philippines and buy one.
I took my 70 bronco with 302 to the accessory shop to have them go through my electrical (i'm poor at electrical stuff) and fix my brake and signal lights. I have no idea why they took off my air cleaner, but had seen it apart when I went by one day (took them like a week to fix my electrical!..should've been a clue)
I picked up the Bronco today and went to stump on the gas as I pulled away and dang it died...checked under the hood, there it was the foam filter sucked in the carb!? They say, twas like that when I brought it in!
Oh yeah, this is the first time I stumped on my gas...stupid me. That's why I have a V8 cause I don't like the power and speed....
Please help me before I kill someone!!!! I'm not going back stateside till June and don't wana drive the bronco without a filter (especially on dusty trails)
rustbucket
That's one of the reasons I hate that filter. My Bronco had one on it when I bought it. Swapped it out pretty quickly. Mine didn't suck the entire filter down the carb, but chances would fall off and get sucked in.
I would recomend anything before sing one of those filters on an engine I care about. About the only thing it can filter out are boulders and small children. They are engine killers. I realize you are in the middle of nowhere worse then most of us who think we are in the middle of nowhere, I I strongly ask that you find a different air filter, something that works.
bmc69
That. x10.
72_EB
66to77
x77!
I hate seeing these filters on engines too. I was just cleaning up the sticky mess on a carb from one last week. One backfire and you'll be sucking this crud right in your motor. Lose it now!
70_Steve
Old Guy
x77!
X123!!! The first thing I did when I bought my Bronco was rebuild the brand new Carter AFB that was full of this burnt foam crap from when I assume it backfired and burned the foam. It had new foam in it, so the PO knew what happened. I threw that filter in the trash and never looked back. I cringe now when I see them on an engine.
blubuckaroo
Grease Monkey
Ridgefield WA
I am a bit surprised that Edelbrock hasn't discontinued those. The only good use for them is to cover the intake while working under the hood to keep stuff from falling in.
bingen
bingen
Cebu, Philippines
Well it looked cool when I got it last year...the only filters you get around here are for small two barrel carbs for Japanese cars!
Am stuck now with having to run with no filter.
