Edelbrock BLACK PLASMA Pro-Flo 4 EFI Kit !!
mitch@wildhorses
Lodi, CA
WILD HORSES exclusive BLACK PLASMA Edelbrock Pro-Flo 4 EFI System for Small-Block Ford 351W CID engines and for Small-Block Ford 289W-302W CID engines. The EFI System comes with a BLACK PLASMA finish single plane intake manifold and 29 Lb/Hr injectors capable of 450 HP with 58 p.s.i. fuel pressure. Click the link below to check them out: https://www.wildhorses4x4.com/category/s?keyword=Black+plasma
dmoses42
Bronco addict
Brunswick, Ga
Can you run a factory air cleaner with this? And will this setup clear a stock hood with new body mounts and a 1 inch body lift? Thanks
Don
WILDHORSES
USA
Should work fine with stock air cleaner. Can't get a lower profile than that. 289/302, might be a different story for 351.
Jim
