Edelbrock Preformer EFI intake
Tiko433
I know just enough to be dangerous
Bolivia, North Carolina
I have one of these sitting in my shop. I know this sits quite a bit higher then a GT 40 intake. I am running a 3 in body lift and a fiberglass hood. I would need to do some measuring to see if it would fit. This is a truck intake the throttle body mounts in front vs the 5.0 car version which has the throttle body on the side. Would there be an advantage over a car intake ?
I have not seen it used on a EB but I’m asking to see if it has been done and if it’s worth it. I’m planning my next motor I need to see if I’m going to use it or get the other intake which mounts the TB on the side.
rguest3
If this Intake is the same height as the Ford Truck intake you will need more body lift. That thing is REALLY Tall.
Just for reference, BC Broncos has a picture in their website of the Truck Intake in an Early Bronco.
There is really NO advantage in using this intake over others.
