Thanks, I realize there is a big difference btw the two "greases" as many refer to them.
See below:
Here is a good comparison on heat sinks and different compounds used on the bottom of them.
"Here is measured data of a few sample greases with 30 watts heat dissipation:
Type Sink F Device F Delta degrees Percent (aprox)
Bare scratched 62.0 63.9 1.9 3.1%
Heat sink compound thick 55.9 57.6 1.7 3.0%
Bare polished 61.6 63.0 1.4 2.3%
Vaseline 62.5 63.1 0.6 1.0%
Dielectric grease 62.3 62.8 0.5 0.8%
Heat sink compound thin 56.2 56.6 0.4 0.7%
Best result is at bottom. All greases were tested under "scratched" conditions by roughing the heatsink with ~300 grit paper.
Using too much dense grease, like thick heatsink compound, greatly increased thermal resistance. This occurred because compression pressure was not enough to force excess grease out of the area between the heatsink and the resistor tab. When the layer was thinned to a light "wipe" of grease, thermal resistance fell off significantly.
There is essentially no difference between Permatex Dielectric Tune Up Grease and a special heatsink compound used on high-power transistors. Even Vaseline, at 1%, is better than bare metal-on-metal."
I couldn't post the table showing all the variables....
http://www.w8ji.com/dielectric_grease_vs_conductive_grease.htm
Thought I'd just toss this out there...since it also talks about too heavy of a film being detrimental...
