CupricReki
I have the efi fuel delivery system that utilizes the low pressure pump that feeds the accumulator that feeds the high pressure pump for my efi system. For some unknown reason on a warmish day (Or a long day of wheeling), the high pressure pump stops getting fuel.
I have a very high gph low pressure pump mounted as low as possible in the back, and isolated the fuel lines from any heat source i can find. It still makes no difference at all. One thing i noticed is that when the HP pump stops getting fuel i can kink the return line and that seems to do the trick for a bit. But after a while it stops pumping again. I tried to put a pressure regulator on the return line thinking the accumulator wasnt collecting enough fuel but that only seemed to make the intervals in between the pump going dry increase.
Im Completely at a loss as to what to do.
