WorkerBee
I am working on the last few details of my efi swap. I fabricated my own fuel tank and am using the factory explorer pump/sending unit. I also plan on using the ford truck fuel filter with the quick disconnect fittings.
I got a great set of fuel lines from a 93 F150 from the filter forward. The problem is getting from the pump to the filter. I need to get from the 3/8" quick disconnect to the 5/16" disconnect on the filter. I am finding a bunch of conflicting info on what lines I can use. I can do something like this but can I adapt this to hard line and be OK with the high pressure side? I only need to make it about 3' long max.
http://www.summitracing.com/parts/FRA-491989-BL/
http://www.summitracing.com/parts/SUM-2200075/
Or, does someone have a better way?
Or, does someone have a factory line recommendation from a car or similar vehicle? The explorer and truck lines won't really work very well.
any help is much appreciated.
