chuzie
- Jul 21, 2006
- 2,701
I am having a fuel starvation issue on the trails.
Here is my system
Vented fuel cap
Wild Horses EFI 23 gal tank
LP pump mounted to frame rail right next to tank with pre-filter
HP pump mounted on driver fender will
BC accumulator
Fuel press gauge tapped at fuel rail
Return line back to accumulator
Return line back to tank
Vented fuel cap
No aux tank
On 3 separate occasions I have been starved of fuel on the trail which has initially appeared as though my tank being empty. Each time I am off camber either nose up, passenger side down, or a combination of both.
The most recent occurrence I added 2.5 gal on level ground and finally got it primed and started after multiple priming attempts. When I filled up at the station I calculated I had 12 gallons of fuel in the tank at the time of the starvation. My fuel gauge is not operational. My fuel pressure gauge indicates 20 PSI during these incidents but my HP pump is new and confirmed operating during these incidents. Also, the most recent incident occurred within an hour of installing a new LP pump and filter.
I am thinking about installing a LP gauge after the LP pump to aid in troubleshooting but I also am considering removing the tank for inspection. of the pickup.
Looking for thoughts on this issue to aid in troubleshooting tomorrow.
Thx.
Here is my system
Vented fuel cap
BC accumulator
Vented fuel cap
No aux tank
Thx.
