I am going to follow up on your suggestion and check my connections to ensure no neg leaks are present. The concern I have is when I ran my ACC dry, I couldn't get fuel to enter it after the fact until I cracked open the HP supply line to purge air. For whatever reason the system will not recover on its own from such a situation.
This is what broncobowsher posted in response to my inquiry as to why a 4 port ACC is better than a 3 port here
http://classicbroncos.com/forums/showthread.php?p=2331643
"As the LP pumps air into the accumulator it blocks the flow of fuel returning from the fuel rail at the T and forces it back into the tank. Now the accumulator runs dry. Basicly you have a single loop system that has a pressure break between the 2 pumps.
By seperating the return off the fuel rail into the accumulator and the accumulator return to the main tank into seperate fitting on the accumulator you now allow fuel to continue to loop on the HP side and the LP side sucking bubbles has a chance to blow them right back into the tank.
Back to the downfalls of a T on the accumulator. Lets say you have a good LP pump that can pump faster then the HP can. The LP fills the accumulator. The difference in flow goes into the T. Mixes with the return off the rail and back into the tank. If you suck air and the pump can move it, you are just pumping air into the accumulator and blocking the return.
Lets go the other way around, HP pump moves more fuel then the LP pump can (this will also be the case when the LP pump sucks air as the LP pump movong air won't be that good at it). The HP pump is pulling fuel out of the accumulator faster then it is filled. No problem, the excess goes back in through the T-fitting. The flow through the single point off the accumulator is into the accumulator. Yes most of the HP feed is returning to the tank at the same rate the LP pump is removing it (minus fuel burned which doesn't add up to squat most of the time). So you are always putting fuel into the accumulator, never giving the accumulator a place to vent the air out at. How can it get out? You are feeding it with the LP pump, and with the excess flow from the engine. The only outlet is the supply to the HP pump.
3-port accumulators are doomed to fail. That T-fitting just isn't right for the flow to work in independent loops. 4-port accumulators that feed and vet everything off the top (except the feed to the HP pump) are the only way to get an accumulator to work. I think that is why there are so many accumulator horror stories. Systems plumbed poorly because it is easier to screw a T-fitting in them to actually make if flow correctly. I have run 4-port accumulators without issues. 4-port accumulators are how the factory did it in the early years of EFI, just look at the factory part in post #6.
So that is my beef with running a T fitting on the accumulator. Might as well not even run an accumulator at that point."
Sent from my Droid using Tapatalk 2
