oldiron
- Jul 21, 2005
- 1,032
Just as the title reads. I'm confused as to what drives the injector firing order. Is it the ecu? Is it the wiring itself?
Example; I'm installing EFI on an '86 5.0 from a mustang, I have a Ron Francis MG80 SD non-ho sequential harness. If ecu drives the inj. order to match firing order I need an ecu from an 86-88 HO mustang..correct? I spoke with tech support at Ron Francis and am more confused than before. They suggested moving the wiring at the telorvek panel....Wouldn't doing this lead to a 25% lean 25%rich condition between bank 1 and bank2?
If the ecu determines inj. firing order couldn't you use the ho ecu for ho applications and the non-ho for non-ho applications?
Please bear with me as I learn this stuff, the learning curve is pretty steep.
Greg
Greg
