casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
I just finished organizing the ECM wires and relays behind the dash for my EFI and I seem to have created a problem. Tried to fire it up after my little project and the fuel pump did not cycle when I turned the key nor does it run when you ground the wire at the self test connector that would normally cause the pump to run. Tested the power to the relay and I'm only getting about 5 volts same result at the EEC power relay. The power for the relays should be from pin 37 and should be 12 volts if I'm reading my old notes correctly ( Is that correct ? ). So where should I be looking to find my voltage drop?
A few other things to consider,
I drove it about 10 miles Saturday with no issues prior to starting my wiring organization project.
A few weeks ago I was driving it and it shut down on the highway because the fuel pump quit working. At the time I thought it was a loose ground at the fuel pump because cleaning and tightening up the ground wire seemed to fix it but perhaps there was an underlying issue at that time that is the same problem I'm having now?
I'm an idiot and I forgot to disconnect the battery before I started pulling out relays and disconnecting things for my organization project so there is a possibility that I fried something. I did eventually remember to disconnect the battery and I never shorted anything that I am aware of ( No sparks or anything along that line ) so I think frying something is not the likely culprit.
I have not tried to pull codes yet mostly because I'm too tired to accurately count flashes on my check engine light.
Any suggestions on what to test would be appreciated.
