I converted my 72 Bronco to EFI (1989 Crown Vic) 6 years ago and it ran great for the first 2 years. The Bronco was stored for the next three years at my parent's house while I was stationed overseas. My dad started it every few months and it always started with no issues. I got it back out of storage a year ago and have driven it periodically with no problems. Last July, I drove it 12 hours from my folk's house to my new home in Texas (95 degree heat) with no problems. Approx two weeks ago, I was driving home from work (approx 35 minute drive) when it started to miss and after approx 1/2 mile, die. I have a fuel pressure (measured at the fuel rail) which never showed less than 35 psi so I don't think I have a fuel issue. The miss and stall were like a points ignition that has burned the points. When attempting to restart, the fuel pressure remained steady and the tach was jumping which led me to think the ignition was functioning to some degree. After approx 20 minutes, the engine started and I drove the remaining 2 miles home with no issue.
a few days ago, I tried driving it again and the same thing occurred after 30 minutes of driving. I again was able to drive home after waiting about 20 minutes but it di not run correctly. The ignition would idle fine and run OK under light load but would miss under any load (going up hill or accelerating). The engine stalled again but I was able to coast into my neighborhood and into my driveway.
I removed the ignition module from th distributor and took it to Autozone to test. The module tested bad so I bought a new one and installed it. The next morning I drove the Bronco to work (35 mins) with no issue and drove it several times during the day (10 min or less trips) with no problem. Approx 10 minutes into the drive home, the miss started and engine died sortly thereafter. After approx 20 minutes, I was able to restart and drive home but the miss was getting worse as I drove and was made worse when the engine was under load (hill, accelerating).
I plan to take the new ignition module back to test it but would appreciate any insight from anybody who has had a similar issue. After sitting overnight, the Bronco starts right up but I am a bit hesitant to go past the end of my driveway in it at this point.
Thanks,
Layne
Thanks,
Layne
