efi problem [mustang system]
lars
Been here awhile
NorCal flatlands
Yep, you're right. I keep forgetting that you've said several times that the light stays on. Not sure what all can cause that, because it could literally be telling you something is wrong somewhere else externally.
But then the fact that you can't get codes is another kicker.
Are you certain you're following the odd code checking procedure from the get-go? I can't even remember how it goes and have to read the instructions every time.
You probably have them memorized by now!
The check engine light receives power from the ignition switch-controlled source (I keep wanting to call it the main buss- too many years working on airplanes) and is grounded by the ECU. If that wiring checks out and the ECU is grounding it all the time, then the blame lies with the ECU, which could mean... ECU fried.
stupidboy
stupidboy
My wifes porn star.
Morrisdale Pa.
I guess my question should be , How do I check to see if it is grounding it all the time?
lars
Been here awhile
NorCal flatlands
A simple test is to just disconnect the ECU. Turn the ignition switch to ON. If the CEL lights up there's a problem with your harness, as the ground for the light is supposed to go through the ECU. If it's still on that means there's a short to ground in the harness somewhere. If it's not lit, then the ground is through the ECU, in which case it's likely defective.
stupidboy
stupidboy
My wifes porn star.
Morrisdale Pa.
I can do that
lars
Been here awhile
NorCal flatlands
Well the light went out with the ecu unplugged
OK. If you want to dee-double-dare check it, connect a piece of wire from a convenient good ground point to pin 17 on the ECU connector. With the key in the ON position, the CEL should light up. That's just imitating the ECU grounding that wire. If it lights up, you have confirmed that all is well with that circuit, and the blame is likely with the ECU. Which sux, but by throwing money at it you can solve that problem.
The ECU rebuild service you linked is starting to look pretty good. Considering that I've seen used A9xx ECUs selling on eBay for over $500 lately. Ouch.
Wow, not cheap anymore. It almost makes the aftermarket computers sound affordable. At least you get more for your money.
The stinger performance version of the FAST computer which is in a ford case) and the Holley terminator is it? Standalone computer and harness to work with your engine.
Starting to look mighty appealing
jmhend
I'll start looking for a computer..
a9l computer great shape. $300.00
An A9L is the old standby manual transmission Mustang ECM. Usually exactly what you want.
But did we verify what you were running already? I think you said you’re running the aftermarket EFI harness, so it’s got the standard jumper wire to allow you to toggle between a manual and automatic transmission computer?
If you get a used computer it would not be a bad idea to have a look inside. And maybe even have it tuned if you’ve got a mishmash of parts you’re trying to run together.
I guess I should ask this directly. Did you install the new EFI harness? If so, then when it went in did you put the (gray and black wires I think?) transmission jumper wires in the correct orientation for your existing computer? The way this particular harness allows for either computer is that jumper feature. Would let you run for example an A9P (automatic trans Mustang) the next time around and just flip the jumper wires so that the new computer won't get fried by having some wires reversed.
And sorry if you already mentioned it, but what is the code on the computer are you using currently?
stupidboy
stupidboy
My wifes porn star.
Morrisdale Pa.
I put the harness in and followed the directions for automatic trans on those wires I am using an a9p ecu which is for automatic transmission.
jmhend
Paul,
I don't recall the jumper being in the instructions but I could be wrong. If I read this correctly he bought a new harness from WH. I can't comment about the codes but I think he said the light was on constantly.
From WH:
https://s3.amazonaws.com/cdn.wildhorses4x4.com/downloads/WH/6048 07-25-18.pdf
Pin out drawing: (look at the top left)
http://www.veryuseful.com/mustang/tech/engine/images/88-91_5.0_EEC_Wiring_Diagram.gif
I’ll have to reread the instructions again, but I’m pretty sure it’s there.
And just confirmed that the jumper was set for automatic transmission with the A9P computer.
So all is good there…
