EFI stalls when put in gear
M
MY 4 BY
A few of us have had this issue....see older thread link, sorry, no definitive solution I've found yet. Is yours a problem on cold starts or JUST on warm re-starts as Andrew's and mine is? http://classicbroncos.com/forums/showthread.php?t=229418
Thanks for the link, and the suggestions from everyone. It does seem to be more of a problem when the engine is cold. But after it happens the first time then I begin to compensate by just touching the throttle to get it past the opportunity to stall.
BUCKNBRONK
fresno
r u running a oiled k&n style air filter? u mentioned a idle surge in P/N does that go away when motor is at operating temp? does the idle smooth out in D while stopped.
BUCKNBRONK
fresno
I know u said that u checked for vac leaks around the motor, but one place that gets overlooked is the vac booster for the brakes. pull off/plug or crimp that line.
M
MY 4 BY
I'm using a cone filter, but it's not oiled.
