wesleydax
- Apr 12, 2011
- 331
just got the efi change done. when you start it cold its hard to start. almost like a carb. once started it idles ok. accelerate quick and it stumbles and if you dont let off and catch it it will die. you can feather the throttle and bring the rpm up. I am thinking it could be a few things.
1. tps bad?
2. egr not seated? it is not hooked up i have the vac line pluged
3. map sensor bad?
changed only the upper intake and stuff. base motor is still 302 which ran fine before.
1. tps bad?
3. map sensor bad?
