EFI Swap Electrical Questions
Killer Frogs
Amarillo, TX
I think I'm close, but wondering if I still need to ignition module? I am running a 2000, 5.0 Explorer motor, EFI guy customized the harness and computer. Also, are the wires under the dash that plugged into the old motor needed? (Picture Below). If not needed, is one of them hot with ignition?
Thanks!
Timmy390
Conway, AR
Not sure how you're EFI harness is wired but the way I did mine, it's not needed. I'm running my complete EFI setup off it's own fuse and relay box with just 2 wires hooked to the ignition "hot in both start and run" and hot in acc/run.
I didn't pull the old connectors back through the firewall as you have done. I cut the connectors off the engine harness side, clipped the wires done close to the plug then covered them in a think coat of liquid electrical tape. Once dry I plugged them back into the connectors in you're photo. They now lay on top of the lower intake.
Yes they will still be hot unless you have modified the original harness to eliminate them.
Tim
Not sure what you mean by module, as your '73 would never have come with one, so does not have factory wiring for one.
But with EFI, whether using a distributor or coil pack (all you said is it's modified) all ignition duties are completely controlled by the computer and are accommodated in the engine harness. No chassis harness wires needed at that level.
Sounds more like that means you'll be using the DIS and coil pack, rather than a distributor? Or was that what the modification was for?
Either way, non need for those wires (yet) to control anything on the engine side, other than perhaps as a keyed power source for the computer. But then that would depend on how you have it wired, and where.
As already mentioned, if you're going to be retaining the original gauges, then the water temp and oil pressure gauge sending wires go through there.
Remember, the sending units for the computer/engine and the sending units for the gauges are completely different and incompatible with each other. You can't use one set of sensors for both here, like they would in most newer cars.
Yes, but with a catch.
The red connector should have a Red w/green wire. That's your old coil wire but is a resistor wire which won't provide 12v under load or after it heats up some. It's designed to reduce the voltage to keep the old ignition happy.
If you're using it to energize a relay, or something that does not need the full 12v or need much current, it should still work. Or you could bypass the resistor part in the middle and simply jumper that directly to the same color wire at the ignition switch.
If there is another wire there, something like Gray with a blue stripe maybe? Or Blue with a black stripe? Then it's 12v with the key too.
You can test these easily with a voltmeter though. Since we don't know the condition of the old wires, you're better off physically testing each one anyway.
The square-4 plug is your old neutral safety and backup light connector.
You may or may not need it, depending on what else you've done.
Killer Frogs
Killer Frogs
Amarillo, TX
thank you. The module picture below is what I was asking about, but sounds like I don't need it. The other pic is the ignition box I will use. I think all the wires for the gauges are labeled, but I'm sure I'll have some more questions.
ransil
that is the voltage regulator, you need that. better option is to swap to the electronic type that on is a mechanical type.
ask for on for a 77 bronco height should be half the one you have.
Timmy390
Conway, AR
Looks like you have the Explorer serp front dress? If so you upgraded to a 3G alt correct? So that old stock voltage regulator is not needed with the swap. If you still have the stock alt, then yes you needed it.
Tim
decipha
New Orleans
I take it you are using the 2000 explorer ecu as well correct?
If so, you do not need an ignition module nor the alternator voltage regulator as stated since your using the 2000 explorer alt (i hope)
